It should be good. It is an auto-reset circuit breaker.
yes it spins backwords i have no idea why i have black ground off the starter its self should it be a power wire?
have to turn housing 90 degrees to swap polarity on starter its self iv done successfully 1 time with amazon starter but haven't bin able to do it with stock starter some one stole my other starter when it was at a shopIt should be good. It is an auto-reset circuit breaker.
What do you mean "clock" the starter? It is turning backwards?
i have looked at wire diagram 1000 times and everything seems to be hooked up correctly bin having this problem for a min with starters i may need to just order one off amazonhave to turn housing 90 degrees to swap polarity on starter its self iv done successfully 1 time with amazon starter but haven't bin able to do it with stock starter some one stole my other starter when it was at a shop
the one i have on the bike now it a stock Suzuki part but idk why its spinning backwards all wiring looks correctNon-OEM starters are very likely to give you a hard time. I don't have a spare one or I would send it down there.
head light is off the bike stand switch was "bypassed"(green and black/white trace spliced) i need to make sure the clutch switch is wired correctly idk why starter would be spinning backwards thoughOK. That relay has a primary and a secondary circuit. The primary circuit is for the starter motor and if you can jump the terminals to spin the motor it is good. The secondary circuit goes through the side stand, clutch, kill switch ignition, etc. That is what you have to trace out and trouble shoot
Unplug your headlights right at the bulbs so you don't kill your battery while you troubleshoot.
alright im going to check the switches here shortlyI’ve read somewhere about the starter spinning backwards…..aside from the obvious reversed polarity, it was down to something internal being indexed incorrectly. That was a long time back but likely the issue here. If I can find the article/thread I’ll post a link as it on another forum
so the starter is just bad or would it be something reversed ?alright im going to check the switches here shortly
so what can i do to reslove the starterI’ve read somewhere about the starter spinning backwards…..aside from the obvious reversed polarity, it was down to something internal being indexed incorrectly. That was a long time back but likely the issue here. If I can find the article/thread I’ll post a link as it on another forum
alright im going to check the switches here shortlyWith the key on you should see power to ground on both sides of all those switches. When you find the switch with power on one side and nothing on the other that is the open switch.
The other way to do it with the key off is to check each switch the same way you checked that relay. The open one is the problem.
alright iv had the same problem with 2 different oem starters. when i jump both leads on the switch and complete the circuit i still get 0.00 how would ik if the switch is badErrrmm…..the switch is normally open when the lever is in its normal position and closed when clutch lever is pulled in.
With it sitting there like that, I have to assume it is in the open position so you would get no continuity.
If you put your leads on the wires and close the switch it should show something above 0.00 ohms. I will try to find that article/thread about a starter’s running in reverse.
It’s not on this forum….and I have to weed through a whole bunch of threads to find it. Also, it is not a Suzuki starter….though I’m pretty sure all the Japanese manufacturers use the same Hitachi or Nippon Denso starter motors
