1 - 20 of 27 Posts
If You are going to change the rear sprocket size I would suggest going with the 15/48 combo because gaining 3 in the rear would be like dropping one in the front. If you went up in increments like from the 45 to the 46 then 47 and so on, you won't notice a difference, but if you go from the 45 to the 48 you will notice it. the 110 should work for you. but why not get a 120 link when they are a couple bucks more to be safe.
What ^^ he said.
r_meintel said:
Is a standard 110 link chain going to fit?
Do you know what size chain is on it stock?
I know it is 16/45 stock with a 525 chain. Not sure how many links it is though. I haven't been that bored yet. The chain "Regina" that I am looking to get with the conversion kit is 114 links.
stock setup= 16/45, 525 chain at 110 links. :thumbup:
r_meintel said:
Thanks Krum. I will be going with a 15/48 520 conversion....Today I will let everyone know how it works out.
15/48 :headshake
I just dont understand.............. :headscrat
I assume it is a 600. My 03 is stock geared and will lift in 1st - 3rd. What else do you need. It cones up around 75 MPH in 3rd. Just how fast do you want to go in a wheelie :laugh:
personally i did the 15/46 and it still comes up in third pretty e-z. i gotta feeling on that 15/48 you'll be hitting that rev limiter alot, i do on the 15/46 setup, but then again i do see alot of people going 15/48...shit try it and if you don't like it slap a 46 on the back. :thumbup: and that chain that your looking at should work perfect if you go with the 48, or 2 links out on the 46.
Exactly, let him do what he likes, the more comfortable he is the better!!!
:rock:
Discussion Starter · #14 ·
Well I did the 520 conversion with 15/48. It takes off like a bat out of hell from the line. I couldn't believe the weight difference between the stock rear sproket and the one I picked up. Its a little hard to keep the front tire on the ground in 1st and second 2nd but what the hell. Thanks everyone for the input.
I'm gonna do pretty much the same thing on my gsxr 1000. Go with the 520 kit, but I think I'm going up 4 in the rear. it'll be loads of fun! :thumbup: :clap: :arsenal
ski, you know your tire is never gonna hook up why would you do that, compared to our 600's you have like +20 in the back, anyhows let us know how that works out 4 ya. :thumbup:
I like spinnin the tire through the corners its fun, and the only difference is gonna be 1 tooth, because right now I am 14/42, and I'll be going 15/46, so not too big of a deal. When its warm though I'll hook up good.
If Sprocket specialist ever gets their heads outa their asses and gets me my sprocket, on my 750 I'll be running a 15/74. hahaha :arsenal :thumbup:
1 - 20 of 27 Posts
