1 - 2 of 2 Posts
I am looking for some help. I removed my catalytic converter and installed an extension with a slip-on muffler. The problem I am having is that an "F-1" code is blinking on my display and I need to know how or who can help me turn it off. I have a power commander to install but waiting to correct this 1st. Any help is appreciated!
Thank you, Floyd
Mod of the North
Look up SET valve removal. I believe there was a butterfly valve in the cross peice and when the actuator is removed it shows a fault. Did you remove it? Pulling the correct wire from the ecu resolves it.
Reactions: rv6john
1 - 2 of 2 Posts
