1 - 8 of 8 Posts
Removed a data tool system 3 from my GSXR. Now when I turn the ignition on I do not here the wining sound of everything turning on?
Is there anyway to get this working without replacing the loom?
Another question... Will the bike start without the instrument clock connected?
By the way it is a GSXR 750 K4.
I dont know what the "Data tool 3" is, but the sound you hear is the fuel pump. What happens when you try to start it? Are you sure its in its in neutral since I assume the whole cluster is unplugged?
It is definately in neutral. I checked it by rolling the bike back anf forth. Datatool is the alarm that was on it. I will have to see if the alarm was wired into the fuel pump and reconnect it somehow.
Does anyone have the manual for the K4/K5 750 out there?
Mod of the North
I know this is a an old post but did you ever fix this problem as today the same has happened to me.
First off that is a killer user name. Second, this is real old, you are better off starting your own thread in the tech section and the boys will help you out.
1 - 8 of 8 Posts
