Has anyone done this? i think i can take the bottom peice off the shock and then the spring should slide off. I have never taken one apart so i dont want to mess anything up. any tips? I am just pulling the spring so i can paint it black. i hate the yellow.
Thanks
Joe
You'll need a spring compression tool.
It is under tension and could be dangerous to remove without one and will be difficult if not impossible to reinstall without the tool also.
Thanks
Joe
Thats not a bad idea, I though bout taking mine off and painting it orange.
· Premium Member
+1. Do not...DO NOT just remove that place. It's just like a strut on a car. Under high pressure. And if you DID get the place off by hand, as soon as it came off pieces would do flying, probably losing a couple hundred dollars in parts.
Take it to a shop and bring a black rattle can with you, and offer a tech to do it for beer or a tip. :thumbup:
Simple spring compressors are cheap as all hell. And don't rattle-can a spring, I think the paint would come off due to the movement of the spring. I would recommend powdercoating.
Its a motha.....to get off , simple spring compressors aint the trick , well the ones you use on a car atleast aint the trick. If the shop will do it for a couple bucks take it . I speak from experience Bro , I did get it done but it was hell....Used simple coil compressors, but they are not designed for such a small spring . Any way take it to a shop pull it POWEDER coat it........not rattle can it and you will be happy. Thats what i did to my spring pulled it myself powder coated it myself........it looks gr8.......peace out:thumbup:
