Hello, I own an 05 Gsxr 600 and I was wanting to raise the bike up because it looks and feels low and it has the vortex lowering link on it and it’s set to the highest setting with is the same as the oem link, is there another way to adjust the height?
Administrator
^ Yes, you can find the stock links really cheap used on Ebay.
So it is now in the shortest link hole?
Where is the preload adjustment set?
Pictures?
And as Sub said, adding a 5mm shim under the top shock mount is common.
Pictures?
The vortex Links on it right now are in the highest hole which is the same as the oem links. I bought some off eBay already which is why I’m asking how else to adjust height, I can send pictures when I get home
