Will the rims off a 2006 Hayabusa fit my 1999 GSXR the rims are 17 in will they work
Dad Bod Super Mod
I am thinking rim (or more accurately tire) width may be a problem if the 1999 swing arm is narrower. You may also need to change the spacers that center the rim assembly. Do a quick search of the OEM part numbers for both and compare. Same part number is likely a good fit.
I am moving this to the "Does it fit" section for you.
1995 GSX-R 750
They used different axle sizes over the years. So in addition to spacing, the diameter of the axle needs to be looked at as well.
So in addition to spacing, the diameter of the axle needs to be looked at as well. This is very important :D
