1 - 20 of 57 Posts
Hi guys
Is it a good option,if the only I have to sleeve the engine,gsxr 1000k6
Replate here... impossible.
I have talked to a guy who sleeves but he says that the wear would be fast...any opinions??
Thanks guys
Thanks for the reply billv
here I mean Spain.
I have just emailed the guys you mentioned.
I am looking for engines but the asking prices are way to high for a used engine where I ask what Comp values are given and all I get "it's a running engine"
I did a comp test on mine and it's dead low...9,5bar
So,if price is ok and they do the service I would be also looking at rings and shells....
Have called and they tell they can't do this engine as it is not only cyl block,not possible as the upper part of the casing is part of the block
How do you know your compression loss is a problem with the bore? A quick hone and new rings might be all that's needed.
I had the engine a part, and on cyl1 did see that tiny score...
Valves are ok, I was thinking as you said..flexhone to deglaze and rings...
I've never done one of these engines but I believe the cylinders are nikasil plated and honing is not recommended from what I've read. I did some research when I was doing my KTM and just a good scrub with scotchbrite and detergent is what I came across most. There is a ton of information with a google search.
Discussion Starter #9
That's correct, at flexhone for nikasil deglaze they recommended aluminium oxide 250# for just a quick clean to get the cross pattern back.
Btw holeshot racing can Do the replate,they charge 600 pounds for it plus shipping go and back
Discussion Starter #10
Another question,is it safe to lap the valves? These are ti valves
The service manual recommends against it, stating (3-39) that the valves have an oxidized surface finish to resist wear and lapping will remove it.
Discussion Starter #12
Thanks,just as u thought
Replacing with steel valves if there is a need...would I loose top rpm limit? Heard that steely don't like high rpm
Discussion Starter #14
Thanks Chuckster, anyone mounted them keeping factory rev limit?
Not planning on doing new rings,shells and then blasting it due float
First of why? You're asking questions around a solution, but not explaining a problem. Have you gauged the valve/seat interface?
I get this thread has to do with a compression issue. What did you do to diagnose it? Or are you just going to throw parts at it?
Discussion Starter #16
I had the engine out before and the sealing of the valves I one of the cylinders is not the best, I took the cams out and poured some gasoline on all of them,3 kept the gasoline and one lost it in a period of half day.
Second
Rings will have to put in as comp on all are around 9 9,5
The questions are there as I will be pulling out the engine soon again for all this changes
You could check the seat with the procedure shown on 3-36. Note that the lapping tool is just a convenient way to turn the valve, not to lap it. If it isn't seating correctly, a seat touch-up per 3-37 to 3-40 may be in order. But I really consider that as a task for a specialist.
Discussion Starter #19
I might have chance to get a k7 engine, are the engine mounts location the same or do they change,in short,would it fit? For the rest of cables ecu etc...no problems
I think k5-k8 were the same family, so it should be a direct swap. I don't think the redesign came until k9. Go on the parts fiche and compare the part numbers on some of the components. If there's a big overlap, that should be enough. Frame and wiring harness specifically would be telling.
1 - 20 of 57 Posts
