What would cause oil to leak out of two of the bolts on the left side case cover? They were a little lose so i tighened them down pretty tight, but they still seem to be leaking oil. Should I maybe take them out and put some silicone around the head of the bolt and then put them back in? Any input would be great. Thanks
where on the case cover are they?
The two towards the front. all of the top and bottom bolts where tight and aren't leaking. It's just the two in the front, and when they drip, it blows all on my shoe, don't have the side fairings on the bike right now. Any idea? Thanks
If that cover has been off, then the wrong bolts could have been put back in, or the gasket could be torn by those bolts. You could try the silicone but I would see if you need a new gasket first.
