1 - 20 of 22 Posts
Me and myself decided to do this lol aaand it almostly didn't fit. Had to tilt the wheel and spin the wheel to get the chain on. Afterwards sat right where it was before with new chain 1.5" tension play. It's like half 1/4" away from swing arm "crown" but I love it. Less power wheelies more center life. Love it :cool:
Not sure from your post. I think you put a 600 swingarm on a 1000?
Just 200 60 tire.
Oh, Ok, where did it come off of? You were running a 200/60 tire on a 600?
Oh, now I get it. you put a 200/60..., nothing about a 600 then.
makes sense if your track riding not so much for street. Track you have more road to engage. Street 190 allows for quicker turn in side to side. Only ads weight.
Are you aware that larger tyres mean you have to lean deeper for a given corner? So, larger tyres=slower cornering.
You need smaller tyres for faster cornering. The question then is whether the tyre is fit for the acceleration traction, which is down to the bike weight. I don't think there's a benefit in going over 180 on a <200kg bike, probably 160 is better but if Suzuki say 180 then I'll take their word for it.
Also, with a new wheel rim, make sure the chain sprockets are aligned. If there is a lateral displacement the chain and sprockets will wear very quickly.
· Administrator
I've heard and read that but never thought it through. My assumption is that the center of contact with a wider tire moves farther out as you lean the bike so you need to lean more to get the center of gravity inside enough to counteract the centripetal force which is unchanged for a given speed and radius turn.
I recently went from a 160 to a 150 on my sumo and the bike definitely turns better.
  • Wow
Reactions: Todd_Sails
Discussion Starter · #9 ·
True but I'm 90% on hwy low 40s high 50s this tires is absolute perfection especially in cold wet conditions, I don't have to worry about no grip. I commute more than canyons basically, taller center. More center life etc.
? This tire looks like it's done a few laps on the track?
Tire Wheel Land vehicle Vehicle Motorcycle
And clean your motorcycle LOL
This doesn’t increase your contact patch tyre pressure does. Like I said this isn’t very useful unless on a track. I get maybe in theory more tire means more grip but your bike weight already sets the standard for contact patch. And so does tire pressure. Plus bigger tyre means more weight.
Nor does it mean tire last longer. There’s plenty of YouTube manufacturers videos explaining this. Bridgestone also has a video.
Discussion Starter · #17 ·
I'd be wary of that setup. The chain is running extremely close to the tyre. It doesn't leave much room for tyre flexing.
I'm ur lab rat. So far feels great, especially speeds. I ride min 10k miles a year. 2017 was 20k miles year. We'll see in 2000 miles lol
I didn't mention pressure and patch. Just good cold and wet grip. Plus more center life. Pressure is personal preference. Softer carcass I stick to 34 38 especially R10 and RS11
Didn't mention pressure and patch. So not sure how did that make it here.
I am for 200/60. It's better than 200/55 on our 6 inch wide rear rims. A bigger tyre runs lower pressure by half to a few psi.
I am using 120/70 + 190/50, with the rear reaching the edge while the front having a finger's width of chicken strips. So I think it's worth looking at how the front wear matches up with the rear in making that decision.
1 - 20 of 22 Posts
