1 - 19 of 19 Posts
Post in the tech area and performance and you will get a answer. I will not answer on this post :cool:
also what yr bike make model (i know 600)
down one in the front and up three the rear if all you want to do is wheelies. I would not go any lower then that. But that is just me.
I guy here in odessa put a 72 tooth in the rear and it would come up in 6th from 5 mph.But his bike toppend went to shit and he had to start off in thrid instead of first. He blow his motor in about a month though.
BTW stock gearing on the front is a 16 tooth. I do not know what the stock gearing on the rear is.
Discussion Starter · #10 ·
thanks to all you gsxr peeps
well i happen to take one down in the front its ok but i want more,--so im gonna go with the 2 up in the back-----do you thimk ill be able to keep my stock chain?? the bike has almost 4,000 miles on it?
yea, you will be able to keep the stock chain.
honestly -2/+2R is too much, -1F/+1R is perfect and my 600 will come up outta 3rd with no bounce, just so you know it's a 15/46 setup, but it's your money so do some research and do it the way you wan't. goodluck, KRUM
Weight and Sprocket choice
how much does body weight have to do with your choice of F/R sprocket geared for wheelies. i very between 195-210 throughout the year. i find it somewhat easy to get-up with stock sprockets, but am looking for more speed and longer rides..lemme know. :arsenal
if your gear ratio goes too high yes, it will come up hella easy but for short distances because of the rev limiter, i'm 160lbs on a 03' 600 w/ -1/+1 and it will come up out of third and give me the distance that i am looking for and be able to hold it down the interstate, not to say that is safe but thats just what i like, i'd say the great thing about sprockets especially the front one is there not to expensive so you can get a few and find the specific setup for your type of riding, and as for weight, really shouldn't make too much of a difference sence your weight is shifted toward the rear of the bike before lift-off, so i'd say if your gonna go up in ratio don't go too high if it's distance your looking for, just what i've learned from my wheelies. :thumbup:
4shizzle dizzle....man i was ought in vegas 2 weeks ago and it was hella cold out there, i didn't expect the desert to be cold but i found out i was wrong that week, bet the bikes run great out there when it's cold and dry, it gets cold down here in new orleans but stays humid. anyways glad i could help bro...peace...KRUM :thumbup:
1 - 19 of 19 Posts
