Just use more brake. My front brakes never squeaked that I can remember when I still had the stock pads in. My rear brake will only squeak if I haven't used it for a while and I'm using it very gently. When I put EBC pads in the front they started squeaking quite a bit. I started stopping harder and the squeaking went away. You don't have to use maximum braking power, just a bit more than a normal car driver uses. Nowadays if I am stuck riding in traffic for a while they will start squeaking again because I can't use enough brake without risking getting rearended. But when I get out of traffic all it takes is one good stop and they stop squeaking again. Your mileage may vary.
