Can someone please give some ideas I’m at a loss. I have a 15 gsxr 750. When I bought it the steering stem had a knock to it. I jacked it up and the wheel had play from side to side not front to back. I can see the steering stem lower bracket move a little. I replaced with stock bearing and still the same thing. I replaced with all balls bearings and changed both front and back wheel bearings but I’m still getting the play from the bottom yolk. I even put a thin washer under the race to see if the bearing would finally set. But it’s till not seated all the way in the race. The bearing is driven all the way down on the steering stem. Idk what else to do. Any feedback would be highly appreciated.
