1 - 14 of 14 Posts
· Anti-squid moderator
Tech-spec is a much better product in looks, variety, quality of the adhesive, and Tech-spec doesn't look like you glued on a shower mat to your bike like Stomp Grip does
Genious... ordering a black set of something tomorrow, whatever's cheaper, lol. Something that keeps my crotch off the tank is going to be worth every penny...
But I like the shower mat look! :D
Seems to be alot of that. I had Stomp Grip and it never held up on any of my race bikes. Some days it gets well into the 100-110 degrees with heat index and they just slowly slide down the tank after just a few laps. I installed them correctly (not on a cold tank). I switched to Tech-Spec and have never had an issue. You can also remove Tech-Spec a few times so if you switch race bikes you can just re-stick them...can't do that with Stomp Grip.
So they DO shift around in the heat? I was thinking about getting the stomp grip but wasn't sure living here in AZ, where summer's coming up fast, if they'd stay put. Looks like Tech-Spec is the way to go.
Definately get Tech-Spec for AZ. I've raced in 117 degrees in Texas and mine didn't move. Tech-Spec also includes a matching tank pad so your belt buckle or zipper on your leathers doesn't scratch the bike
1 - 14 of 14 Posts
