1 - 12 of 12 Posts
I have removed the fender even if there was no tag there it still would scrub the bottom of the rear fairing. I know you can buy proformance shocks but I need a solution that doesn't cost thousands or hundreds of dollars. I ride by finance on it all the time and since I stretched it out we can no longer ride together. So I'm looking for something that I can do. I have already hardened the shocks.
yeah unles you have it slammed, just stretching it wouldnt do that.
Are they extensions? If so It should have actually lifted the rear up a tad. At least mine did. Post a pic so we can get a visual
Get a new undertail and mount the tag further forward. My tag doesn't scrub my tire at all. Here is a pic.
It would not let me view your picture!!!
my bike is slammed and they are extensions the swing arm is stock so its not installed wrong because it has never been touched. The tag is moved as far forward as it can go any further and it would have to be mounted on the rear light.
your not doing something right, i stretched mine, lowerd it 3inches and my tag scrubbed when i hit a bump. (or the railroad tracks at 60.....) i screwd it in to the undertail so its flat with the undertail now, not very visible but there not much other things i can do, you can actually make a mount out of a piece of angle iron that you can bolt between the rear foot pegs, that will work fine, very visible and not hitting the tire.
I droppped mine almost twice as much as yours and pulled the tag up towards the taillight and ride with the wife on with no problems. So I dont know what else we can tells ya.
1 - 12 of 12 Posts
