1 - 3 of 3 Posts
I have a 750 and I've been wanting a little more punch coming out of the corners. I was set on going up 2 or 3 teeth in the rear sprocket, but then someone started suggesting i would be better off just going down one or two on the front sprocket... suggestions?
Its the same thing.... Down 1 on the front is like going up 3 on the rear. Much more then that and you will have to get a longer chain.
It will def. help you pull off the corners harder it will also make the front come up a lot easier so you have to watch for that as well.
1 - 3 of 3 Posts
