I just bought a set of their 1.5 inch risers, they are good quality parts, and well constructed.:thumbup: They were easy to install and definately give a better riding position.
I did have to make a couple of modifications to them, one was I had to drill the holes for the switch housings and also drill a hole so I could mount the front brake fluid container. The other mod I did was not neccessary, however I cut about 1 inch off of the handle itself so it would be the same length of the stock clipon handle and not stick out too far.
I know some of the people on here had asked about clipon risers, so if anyone has any questions about these particular ones let me know.
swatt riser question
Since you have purchased the risers, do you find that it helps you sit in a more comfortable riding position? I spoke to the Swatt folks and they said that the risers only go up and not back. I was wondering if that would help me, as I was thinking about ordering the 2.5" risers. These are certainly alot cheaper than the Convertibars! My hands get tingly when I lean on the bars and was hoping the Swatt bars would help that. Any info would be appreciated.
Thanx - Paul
It deffinately helps make the riding position more comfortable:thumbup:. I used to have the same problem with my hands and wrists going numb. Now I can ride on long trips and not have any problems.
