you need a sync stick to hook up to a vacum line or port on each cylinder.There are screws inbetween one and two,two and three,and three and four tb's.With the motor runing you then set cylinder one and two together then three and four after that you adjust the screw between two and three and you might have to adjust the idle.I hope this helps you out and I didn't throw you for a loop. good luck
