1 - 20 of 27 Posts
Hi, I have a 2004 Suzuki GSX R 1000. I have a problem which I do not know if it is normal. When I start the motorcycle and check with the multimeter the battery with the motorcycle on shows 14.7 volts and when I go up to 4000rpm it drops to 14.5 volts. are these normal ranges? stator and regulator are new and original no cable overheating
12.8 for the battery with the bike off, and 14-15 with the bike running. Your voltage looks normal to me. Is this just an inquiry or is the bike doing something strange with the electronics?
What make is the battery, stator, and rec. Just because they are new does not mean they are quality (OEM, Ricks are known to be the best for these types of things other than some LI bats).
He is giving me the battery with the bike off 13 volts, with the bike on 14.7 and with the bike at 4000rpm it is at 14.5 volts. Isn't it supposed that instead of lowering the voltage when it is at 4000rpm the voltage goes up?
Discussion Starter #4
Well I'm happy to see OEM parts (AWESOME!), however what battery is in it, how old is it, has it ever sat for long periods of time without running, and is there anything else hooked up to it like additional lights or something electronic?
Discussion Starter #6
I just took the voltage right now and gave 12.8. I had it 6 months ago but once it was completely exhausted and I left it on the street because of the regulator, recharged it and mounted the new R / R and the Stator that are the ones that I showed you. there are no additional lights on the front, change the original ones for led light
I have run the bike a couple of times and it works very well. only that it is giving that voltage that I wrote at the beginning
Other than it dropping 0.2v at 4000rpm, is there a problem you're having.
I think it's still normal?
If it ain't broke...
I have never been a fan of non OEM batteries other than some of the LI batteries but that's different. My worry is the battery has degraded and is in the beginning stage of making the stator/rec over work by constantly requiring a charge. The numbers still seem good in my book but I would keep a close eye on it.
Discussion Starter #13
perfect, thank you very much, I will change the battery. What battery do you recommend?
Battery (Yuasa FTX12-BS)
Part #
33610-48E20
If you have never set up a battery please let me know. Its easy but you will want to wear old clothes.
You are fine. That is FAIRLY normal. You do not NEED a new battery. It is said, that other than the OEM battery, you will have issues. You are NOT experiencing these issues, in my opinion. As long as you are getting proper voltage from the battery when off, and charging voltage while running, AND not OVER charging, you are just fine. Ride...
Discussion Starter #18
ok, thank you very much
I wish I had an explanation for the drop in voltage with increased RPM but both my K6 750s do exactly the same thing.
I get about 14.8 at idle and lose 0.2 volts when I go to 5k rpm.
1 - 20 of 27 Posts
