Alright for all you mechanics/troubleshooters out there, I have an issue that I need insight on! 03 Gsxr 1000 This is my track bike. I have never had any starting problems with my bike. I wired my bike a long time ago so I didn't need a key. I also did away with the kick stand switch and clutch switch, so basically I can start my bike and go.
A couple weeks back I was coming back from a track day and when I got home, my boy told me my bike had been idling. Seems as though the bike must have shifted in a way that the canon dancer switched on the bike and pressed the start button LOL funny right!
Weird if you ask me but it happened. My boy cut the bike off and gave me the heads up.
Fast forward – I finally got a chance to look at the bike and here is what is happening. The bike will not start. Symptoms – When I turn the bike on, the fuel pump kicks on and goes off normally. When I hit the engine start button, it activates the fuel pump. So literally, every time I hit the start button, the fuel pump will kick on and when I let off the pump stops. The starter does not engage what's so ever. Any ideas?
Things I have tried – I already replaced the ignition and engine run/kill switch to rule out electrical problems for those two things. I was testing the starter relay for 12v and on all four wires got nothing which was odd, but when I plugged it up the fuel pump kicked on and went off normally. I also got that "click" sound from the relay. At this point I think the problem is relay or starter related.
Does any one know, if the engine is started and you press the engine start button while the engine is started, will starter stay in engaged or does the button go into a block state when the engine is started for safety reasons?
Thanks for all your help on this matter, I gotta get back on the track asap, I got the itch….
-Paul
-Paul
