1 - 8 of 8 Posts
ok guys here's what i got, 01 750 at about id say 1/8 to 1/4 throttle at around 4500 the bike will begine to chug, hit throttle or get off it, it runs fine, only happens at around 4500 1/8-1/4 throttle... the only things that i have done to the motor from last year was, PCII(zero map right now), pair valve, 4 short stacks(cut the two center's to match the outer ones) full M4, could this be b/c it needs to be fine tuned with the PC??
if i can get my computer to "find" the PC then i will be puttin in the Full M4 map(005 map) thanks
while i have this thread... is it just my bike but it ideals around 1000 but sounds like its got a cam, alil up and down sound.. not much to move the tach. but u can deff. here it...?
gixerfast said:
your idle should be higher like around 1300-1500. adjust it after your bike is hot up a few thou and you be good.
Idle should be 1200rpm
Discussion Starter · #8 ·
alright thanks guys...
1 - 8 of 8 Posts
