1 - 8 of 8 Posts
According to what I was told the correct tire pressure is what ever your owners manual says it should be for single or "loaded"....
They say the #'s on the tire doesn't mean anything... Also I was told the air leaks out motorcycle tires quite often so to check it fequently if you want to extend the life of your tires
normal riding pressure is around 36psi, if your banging corners I would suggest around 32psi.
I did not know they had right tires on motorcycles.
1 - 8 of 8 Posts
