1 - 3 of 3 Posts
my 1000 is spinning the tire at third-half track. I was told the rear tire does not have enough pressure on it and to adjust my rear suspension to compensate. Question is, do I make it stiffer or weaker to add more pressure to the ground at half track. thanks
need more or better explanation... what kind of tires are you running? is this at the track or on the street? what tire pressure are you set at? did you ever set the sag on your bike for your weight?
1 - 3 of 3 Posts
