Todd's K6 Liter Track bike - new to me
5439 Views 83 Replies 9 Participants Last post by  Todd_Sails
In an effort to somewhat preserve my K5 Literbike, I bought a K6 Literbike just over an our away from me.
This bike is well set up by the original owner.
In a nutshell- the Original owner had crashed it on the street, Bought it back from salvage and built it into a failry well sorted track bike.
The original owner had had the motor worked on and he posted in this for sale thread that it dynoed then at 179 RWHP.
Here's the original For Sale thread from STT forum, it sold then in June, 2016.
Then my PO sold it to me 2 days ago.
He had mods to it as well.
I guess the motor went in 2017, cause he had the motor completely rebuilt by Turn One Racing. PO says he thinks it put down 175 RWHP after that build.
In this invoice, it also states 'degreeing cams'! Maybe it has those changeable cam sprockets too.
This is from my sellers STT post:
Bike comes with some spares/extras including:
  • Extra set of wheels
  • Champion generator + Chickenhawk tire warmers
  • New Suzuki clutch kit (doesn't need it yet, but have the kit)
  • Pitbull Axle pins
  • Front + Rear stands
  • Extra belly pan
Bike upgrades include:
  • Bazzaz traction control + fuel mapper + quick shifter with TC activation light and fuel map switch
  • Woodcraft rear sets
  • Forks have Ohlins internals
  • Rear Elka shock with high/low frequency adjustments
  • Brembo 19x20 master cylinder
  • Brembo calipers
  • Ohlins steering damper
  • Vortex quick release fuel cap
  • New radiator (this season)
  • Replaced coolant hoses with new silicon hoses (this season)
  • Motion pro throttle and start/stop switch
  • Full exhaust with low profile muffler
  • Manual cam chain tensioner installed
I've got it now. The fairings are a little rough. My seller states he low sided it a few times LOL
He rides in the STT Advanced group, and it still has the A sticker from a TD weekend in October 2021.
See less See more
41 - 60 of 84 Posts
Uh.... that's an engine mount broken.
Reactions: 3
Sry about the off... and the bike.
Get well first!
Get well first!
It was a month ago. I was good and my sprained hand is nearly all healed.
But it's not broken all the way thru either. I'll investigate further in the next few weeks by getting that slider/bolt off there.
Unfortunately it looks like the part of the frame your engine mount goes through has fractured straight through...
Automotive tire Gas Rim Automotive wheel system Auto part
That looks like a terminal event for the frame. That sucks! 😞
See less See more
Ahh, that'll buff out! LOL
I'll explore it more in the next few weeks.
11
Well, I got off my but and disassembled a few things from that 'off'.
The left frame slider.
I had a Hex that fit the bolt, and I used my steel pipe/cheater bar on the end and tugged like hell.
Using no power tools, I got the frame slider off. It's bent to shit.
Now a look at that mount. B/C all the forces were from the top, only the bottom portion is damaged, with all the meaty portions of the mount still intact.
There is also this frame/engine mount behind it about 4" away.
This is the upper fairing mount screw. Quite the bend on that when just holding the fairings too.
Here's the multi mount plate- Vortex. You can see where the metal 'gave' and cracked. The rear set was bolted in the middle holes near the bottom. You can also see where the whole plate bent to shite!
And lastly, the CRG clutch lever broke. Looks like I took a grinder to it too LOL.
I'm glad I finally took it apart. For a 'high-side', not too bad really. I wasn't going too fast though too.
I think I have a clutch lever that will work. I can rig a mount on the fairing that will work well too.
Still not sure what I'm going to do about the cracked outer frame at the mount. I could possibly have the crack TIG welded?
And I'm going to source the rear set frame mount part. It has a part # stamped on back too.
My right hand that was so injured now has an area like a wrist bone dislocation in it though.
You see that 'bump'? That wasn't there before and my L hand does not have it.
See less See more
  • Wow
Reactions: 1
Ouch. Might have gotten lucky with the frame. I know there's a company that makes transverse braces for the newer bikes so the frame sliders don't do that. Saw one on a '12 GSXR at the last couple TDs. One side should have a solid mount, and the other side has a pinch bolt. This looks like the lip on the fixed side. If so, I'd clean it up and run it.
Thanks for the feedback Chuck. My pea brain isn't fully understanding what you're saying here though. And coming from you, I definitely want to understand it. Could you elaborate or explain a little differently please? Thanks
One side of the engine mounts hard to the frame. The other side has bushings/adjusters that allow for a little movement. The hard mount side is also the chain side. Basically, forcing a relative position of the frame, swingarm, and front sprocket. The rear wheel then aligns off the swing arm creating a straight drive line. Parts 13 and 15 in this fiche diagram are these adjusters, and indicate quantity two of 13 & 14 are required. The diagram is a little deceiving. Both parts, as well as #14 go to the right side of the frame. The forward one is where frame sliders mount. If you broke the lip on the left side, it's still a hard mount as long as the meat of the loop is there. It's when you break the clamping force on the pinch bolt for the right side that's a real issue. I think you're good based off the pics. (TBF, I'm thinking seriously about removing my frame sliders).
Naval architecture Mode of transport Automotive exterior Font Watercraft
See less See more
  • Love
Reactions: 1
Exactly the description I was needing/asking for! Thanks again for explaining it so well, I got it this time!
Most of the meat on that Left mount that slider bent so badly on has it on the top. Obviously there are more low sides, and force on the bottom of the bike, where the top meat supports more.
I guess it's not designed as much to have the forces coming from the top, like in a high side LOL
And Lastly, IIRC, it's some type of cast alloy. If I try and bent the part that's cracked at the bottom off- it's likely to break off.
Could I have a TIG weld on it for a little more meat again?
I don't think it does anything than shroud the head of the engine mount bolt. Break it off and smooth off the rough edges.
Reactions: 1
Another update on my Track Bike.
I had purchased the proper Vortex rear set plate for my bike that had bent in the crash. I also got a new suit, Back protector, Gloves, and Helmet. Santa was good to me.
Today I got the Vortex rear set plate mounted and foot peg and shifter. While I was trying to adjust the height of the shifter, I was turning the adjustment rod- a bit too much- Broke it!
I just ordered 2 new ones.
I also used one of my previous Clutch levers to replace the broken CRG lever.
I made sure the clutch switch still worked as it's still hooked up on this bike. It cranked up with it pulled in. Let it out- it won't crank. Perfect.
I still have to mount the newer fairings, check my front pads- I have a new set of Vesrah's to go on it.
I'd also like to source another rear wheel, in black.
Anyone reading this with a straight rear wheel to fit a K5/6 1000 LMK.
See less See more
Reactions: 1
2
My new/used rear wheel arrived yesterday! The rim edges look great!
I'll to to put a rod in it and roll it to see if it's as true as I think it is.
I have a straight one on there now, but it's a white rear, and a black front.
I wanted both black, not white. IMO Easier and better than having the white one painted/coated black.
See less See more
Reactions: 1
Don't you have a balancing stand? Use that to check runout.
Reactions: 1
I do have a way to check.
We're going OOT for a bit tomorrow morning, working today, I'll check it in a few days.
2
So, I replaced my Vortex rear set plate on 1/6/23.
Then adjusting the shifter rod for my quickshifter, I broke it.
2 new rods came a few days ago.
It's snowing today- too lazy to work on it today.
I did put my spare clutch lever on I had, so that works OK again.
I'm debating even painting my newer farings that are going to go on soon too.
I've heard that the chance of going down increases as you paint them. LOL
But I think if I do paint them, of more likely to 'keep my shit' and not go down.
Still on the fence on the painting the fairings.
See less See more
Hello if reading this!
The PO of my Track Bike had told me the tire warmers worked fine. When I noticed the front was so much newer looking than the rear, he stated he had sent the front in for repair and they just sent back a new one.
When I used them last season, I noticed the Rear where the cord goes in the warmer seemed loose and sometimes I had to wiggle the cord to get the light in it to come on.
Then, it was blink red/green continuously. It seemed to work, but not as hot as the front.
Now that I'm getting a bit better and needing both tires hot from the get-go, I decided to sent the rear one back to them for a repair/replacement.
I had heard they have a good reputation/customer support. I called and spoke to a girl/woman who said no problem, she'll email me the warranty/repair form. She did. I filled it out and will be mailing my rear warmer to them. She said and the form says it's often a $85 flat repair fee + return shipping on my CC.
Sounds good. We'll see what happens.
See less See more
Chickenhawk? I sent my front in for repair. The element had come loose and was moving around inside. They said it couldn't be fixed.... If stitching can't be fixed, what exactly does a repair cover?
Not sure Chuck. The paper also states that any used warmer can be used for an at least $100 off a new one.
When I get it sent in, we'll see what they say.
5
So, it hit 50 today- got some more work done on my Track bike!
I had purchased another rear wheel- black to replace the white one I have and was using. I had a black one too but didn't really like the bend in it. It was still usable however. The newer black one is straight and no divots/flat spots.
The new rim didn't have a rear disc, it had bearings though. I noticed that the rear disc that came on the Track bike had been drilled too!
Here's the stock rotor on the white rim
The old black rim has those 'captive spacers' on it. I wanted to put those on the newer rim. I watched a YouTube and was able to put the captive spacer on the newer rim.
Here's the disc and captive bearing on the newer rim. Turns out, the 'captive spacer' part is part of the seal.
I already mounted a 90degree valve stem on the rear also, here the newer wheel/rim
So I got my new slick off the White rim. I used my 2x4's and my SUV to get leverage and break the bead on it. I've pictured that before in my thread on that zip tie method. Then I used my Zip Tie technique and removed the slick from my White rim, and was able to mount it on the black rim WITH NO TOOLS! With the zip ties and a little soapy water, you pop half of it on and stand on the edge and walk it on!
I had just been sticking a fiberglass rod the the axle hole and balancing that way.
Then I realized I had bought a knock off Axle cone things that spins on the bearings- like the No mar balancer- it had good reviews!
So I used it for the first time using my 2 x 4x4 as stands. It worked great!
I got the slick and the newer black rim mounted on the bike no problem.
But before I did, I sprayed the back end, swingarm, caliper and hanger with my Kerosene spray bottle and cleaned it up really nice.
Then, in a few days I'll get the front wheel off and see if I need new front pads for the next track days on Memorial Weekend. I've got a set ready to go on. I'll get the newer fairings on it too!
With newer gear, and getting the bike ready I'm really looking forward to this Track season!
See less See more
Reactions: 1
41 - 60 of 84 Posts
