Could someone tell me the torque specs for the engine mounting bolts on a 05 gsxr 600? as well as the smaller pinch bolts that are used to pinch the mounting bolt? Im installing a set of woodcraft sliders right now but dont have the service manual yet and want to get the torques just right.
This is the K6 specs. Not sure but if not the same its probably real close. Downloading the manual is your best bet.
ITEM N·m kgf-m lb-ft
Engine mounting bolt (Cylinder) 55 5.5 39.8
Engine mounting nut (Crankcase) 75 7.5 54.0
Engine mounting thrust adjuster 23 2.3 16.5
Engine mounting thrust adjuster lock-nut 45 4.5 32.5
Engine mounting pinch bolt 23 2.3 16.5
· Premium Member
You are awesome dude. You don't blow people off, you answer pretty much every question.
Just wanted to let you know, that a lot of people on this site appreciate people like you dude. :thumbup: :clap:
