As the title says, I need some help with my TPS sensor.I have been having trouble with my bike the past couple of months where the engine would shut off when coming to a stop with the clutch disengaged. I checked everything I could, replaced what I could, still no luck. I talked with a Suzuki mechanic and they told me it sounds like an electrical problem, not mechanical. He said to check the ohms reading on the TPS and twisting the throttle.
So, I think the previous owner before me tapped into the TPS wires and made it easy to check if it has gone bad or not. My question is if it a sure way to check the ohms reading, or do I still need to unplug it and check it that way.(I also don’t know what range the ohm reading is supposed to be, I’m thinking 1.5ish to 4?)
With that can I poke the positive end of my multimeter in there and the negative to the engine or negative on the battery?
Appreciate the help!
