1 - 10 of 10 Posts
ok my bike been apart for about 2 weeks getting some stuff polished and rims painted and some little things here and there. i decided to do the tre mod before i put it back together i spliced into the solid pink and the black/white wire ran all the wires correctly to a switch. now i went to turn it on and i get the FI on the cluster so i put it in dealer mode and it says c41 which is the fuel control system i replaced the fuel pump relay and the problem continues should i buy a pump or is it the tre mod i did wrong.
http://www.81x.com/bugman/gixxermods that's how i did mine the switch version.
the easiest way to figure that out would be undo the TRE mod and then you'll know.
Also check all plugs, that they are plugged in all the way. :thumbup:
On Bugman's site he says, "Almost all the errors people have with the TRE are due to using the improper resistor (often people use a 15 or 150 ohm resistor instead of a 15,000. You should probably get an "FI" error if you do this."
then you know its something else. check all the plugs.
the tip over switch cuts the fuel off, ive also notice on the newer suzuks that the preformed fuel lines are starting to pintch wile lowering the tanks. this is caused from the heat. i have had to replace 5 of them in the last 4 months. the first one had me guessing for a couple of days
1 - 10 of 10 Posts
