1 - 16 of 16 Posts
2006 GSXR 600
Hello everyone. I want to install a quad lock stem mount, but I'm not sure how to take this middle silver piece out of the stem since I bought it like this. Still a noob and learning.
296226
That silver piece in the very center is not OEM. Someone has some type of adapter stuck in there.
The spindle is clear all the way through so you should be able to get a long screw driver or similar in from the bottom and push it out.
Reactions: Todd_Sails
2006 GSXR 600
Hello and thanks.
I'm a bit confused there's something I can push at the bottom and the adapter will come out?
What he's saying is you should be able to use some sort of a tool from the bottom and push it up from the bottom. Most likely need to remove the wheel and fender to do so. If you're not worried about destroying it, I'd try and drill it. With some luck, the bit will grab and spin it out. What bike is this? Maybe we can see what OEM looks like.
Mod of the North
I am seeing small tabs inside. My first inclination would be to put a flat screwdriver in there and try to unscrew it. I suspect it may have an expanding rubber washer that is meant to grip the inside of the tube. The square end of a socket extension may work as well. Outside of that tapping it from the bottom with a suitable piece of pipe or screwdriver would be the next choice.
It almost looks like a 5 point star thingy?
Like they said, it's not OEM and if you can loosen it, get a flexibile rod and push it out from the bottom.
2006 GSXR 600
Discussion Starter · #8 ·
Ohhh I'll try that.
It's 2006 gsxr 600
Mod of the North
I'm thinking that a long (6-8") 1/2" bolt may drive it out from underneath. This assumes that it's not threaded so you can't pull it out. My K6 1000 has a 13.5 mm hole and I'm assuming that his is the same.
You are likely correct. On my 2010 a piece of 1/2” copper plumbing pipe was a perfect friction fit for a camera mount I fabbed up.
So new theory. It almost looks like it could be some sort of spring loaded retainer. It could just have a bolt from the bottom to hold it in. OP, got a pick from the bottom up?
1 - 16 of 16 Posts
