Hi I have a O6 gsxr750 my turn signals are not working or my hazards I checked the fuse box the 15 amp is good is there anything else that I am missing?
Does the horn work? It is on the same "signal" circuit.
Is the tail light and front position lights working?
If yes, then you should have power to the flasher unit and I would suspect that to be the problem.
You can confirm this by seeing if you have power on the light blue wire at the turn signal and hazard switches. The switches are wired in parallel so it is unlikely that both switches are bad.
Did someone install LED turn signals on the bike or are they stock?
Power to the turn signal flasher also goes to the front position light, license plate light, and tail light. Are they working?
The Lbl lead that John refers to runs from the flasher to the switches. I'm not sure about this but I think that if you raise the tank, there's a yellow connector near the front where you could check if the lead has power.
