1 - 3 of 3 Posts
Replaced battery, r/r, and stator. Went with Rick's instead of oem. Getting 14.3 volts at idle but not rising when revved. Manual says 14-15.5v at 5k with hi beams on. Is this ok? I know it'll charge the battery but I've been having so many problems with the charging system, I need to make sure this will do.
14.3 is what I see on most bikes and if anything, it seems to go down a tiny bit as I rev the bikes.
You are good.
1 - 3 of 3 Posts
