OK so like you can see from my sig, k4 750,..ive read the service manual bc i noticed some antifreeze coming from the water pump area, after cleaning it and letting it sit i deff. could tell the water pump is leaking antifreeze. So i look in the manual and it says that if the pump is leaking coolant, then i have to look at/replace the mechanical seal and seal washer. Easier said then done, once i pull the pump off it says i need a special tool to get the mechanical seal out..anyone know where i can find this, or would it just be easier to bring the pump into the dealer and say replace this seal???
Thanks in advance..
Thanks in advance..
