1 - 19 of 19 Posts
i got an 04 600 but i can't imagine yours and mine being different.
i use 10w-40 (synthetic or not -your choice) and it takes about a gallon - 4 quarts. buy four quarts coz three isn't enough, but don't pour all four, start checking after 3 quarts and gradually increase.
oh and the amount i said is when you replace the oil filter too. i can't imagine why you'd change your oil without replacing the filter.
i would STRONGLY suggest that you use motorcycle oil.
how many miles on your bike and where are you located??? these are factors when deciding what oil to run.......i have 13.5K on my '04 600 and i run motul synthetic 15-50...i like it in this cali weather
AMSOIL test the best
I have used Motul and Mobil One and have just switched to AMSOIL. They have the best test results for all synthetics and my bikes seem to love it. I have had no clutch\shifting issues, there seems to be a slight performance gain which last longer, and the FZ seems to run cooler.
Just my two cents...
http://www.amsoil.com/
Banned
I run Kendal Motorcycle oil 20W50 petrolium based, but very slick. With filter change, my 03 Gixxer 1K take 3.5 quarts oil.
Hey Hendo,
Some of the other forums that I belong to and the guys who switched to Amsoil, were knocking out there cams in just a few thousand miles. So if you want to continue running Amsoil, keep a good eye on your cams.
i have switched to castrol r4 and i dont think i will ever use anything else the trans is mutch smother and also helps with the high pitch vibration of the 05 gsxr 1000 i have about 5000 miles on my bike
it is about 4.99 - 6.99 per qt
joerocket82 said:
What should i run in my 05 gsxr 600? I bought Mobil 1 ext. performance, but haven't used it yet. I'm having second thoughts, because it is not motorcycle specific.
dont go pouring car oil into your bike :headshake
I've used Mobile 1 Synthetic car oil since my 96 750 was new... It's got 21,000 miles on it, and still runs like a bat outta hell, No problems, and the original clutch (which is finally at the end of it's adjustment) has never had a slippage problem. Come to think of it, I've run Mobile 1 Synthetic, in just about every bike ive ever owned.... No problems whatsoever.
Anti-squid moderator
Manual says 10w40 and 3.3 qts for the 01-03 600's. You will actually put in about 3.4-3.5 qts though. I personally use Amsoil 10/40 and have been since my bike turned 5k miles, I now have 32,000 miles on her.
Hi, I was wondering if it is ok to run 100% synthetic oil in my gsxr? I have always heard that if you run 100% synthetic oil in my 4 wheeler and dirt bike it would make the clutch plates slip because it was TOO good of a lubricant/oil. Is this true?
i started with spectra 10w40 on the first oil change- now im using repsol synthetic blend 10w-40.. no issues with clutch and the bike runs super smooth now. :thumbup: the bike also runs bout 10 degrees cooler than normal.. so i guess its a good thing..
I have been using Mobil 1 (10w-40) syn specific for bikes for 4 years now. No problems and no clutch slippage. I would never use car oil in any bike. My brother does that with his goldwing and he has over 30/k miles on her. But that is a 6 cycl. I have been hearing nothing but good things about Amsoil............
1 - 19 of 19 Posts
