I was wondering if anyone knows if a tl1000 front wheel will fit a gsxr 600. I have a 02 600 gixer. If any one knows whats wheels interchange between the newer model suzukis, give me some info, thanks
It won't fit without some modifications.
The 01 and up GSXR front wheel is not as wide at the hub as the 96-99 750, 97-00 600, TLR/TLS etc.
couldn't you throw some spacers in there to make up the difference?
Well actually it's the other way around.
The TL wheel is wider, so you'd have to figure out how much.
Then I suppose if you shaved the stock spacer down 1/2 the difference, it would probably work
