I'm basically in panic mode for winter coming up if you can't tell from my posting. I want to make sure I get everything done that I need to, and I have another question.
The OEM front rotors, I'm not home so I can't check, what is the minimum thickness?
I measured them months ago and if I remember right, they were maybe 0.1mm over their minimum thickness.
How long will OEM rotors last if they are at or just over their minimum thickness?
When you buy new rotors, OEM or otherwise, how many mm are they usually above their minimum thickness rating and how long do they generally last?
I'd appreciate any help on this subject, I don't want to cut corners with brakes!
