PCIII vs PCV
2 reading
11K views 5 replies 5 participants last post by  bmarcinczyk14
#1 ·
I have a PCIII usb on my bike and have been thinking up upgrading to the PCV because of it's ability to make it's own adjustments on the fly or so they say. Anybody know any more about this and whether or not it is that much better? I am going to put a quick shift on my bike soon so switching to the PCV will have to be now or never as the PCV seems to use a different quick shift unit. The PCV makes it's own adjustments via it's own sensor if I'm understanding things correctly but will this work with a Hindle header as there is no place for a sensor. Right now with the PCIII I have a module to fool the ECU into thinking the sensor is intact. Do I have my facts straight?
#2 · (Edited)
You are correct about the O2 senor eliminator. Bikes with an O2 sensor in the stock exhaust operate as a closed loop system in a specific operating RPM range, and can not be adjusted by the Power Commander alone. If you make adjustments with the PCIII in the closed loop operating RPM range area, the O2 sensor will sense these changes and the ECM will alter the fuel curve accordingly. In other words, the ECM receives a signal from the O2 sensor, see's a condition outside of specific parameters and makes what it feels are appropriate changes. Basically negating any changes in fuel mapping you've attempted to make within this specific closed loop operating range. Installing the provided O2 sensor eliminator is essentially allowing the user full fuel management control over the entire RPM range of your bike. About the only downside is supposedly a slight decrease in fuel mileage.
These add-on fuel management devices that plug in between the ECM and the fuel injectors are just altering the signal sent from the ECM that controls injector timing and duration, based on "their map." This ability to alter that signal is what's allowing you to make changes to the air fuel mixture (i.e.. richer or leaner A/F mixture).
As far as the Power Commander V.... Yes it will create a custom fuel map, with the additional cost of the add-on that gives this device the ability to map it's self. Keep in mind, you would need some sort of provision welded onto your exhaust to accept the O2 sensor, for this device to work. My personal opinion on these devices is this... sure they provide some perceived gain and you didn't have to pay a tuner to dyno tune your bike, but I think we're asking a lot from this little device. I doubt these devices, like the human dyno tuner, are sophisticated enough to really analyze exhaust gases throughout the entire RPM range and create a truly optimal air/fuel ratio for all throttle positions and Engine RPM. If you didn't already have an EFI controller and wanted the latest one offered, that's a different story, otherwise and as far as the auto tuner is concerned, I feel it boils down to money best spent somewhere else. Plus once a custom map has been created for a "street bike" there should be no need to "re-map" unless you changed something on the bike.
I would do the quick shifter. I've ridden a few bikes with them. Lots of fun. Full throttle clutchless upshifts!
#6 ·
sorry to add on to a old thread, but does this mean i would need a o2 sensor delete to get the full advantage with a pc3 for my 750? does my k6 have a 02 sensor i need to worry about?
#3 ·
Thank You, this eases my decision allot. Skip the PCV and go straight to the shifter as planned. You are well read my friend!
#4 ·
That guy does have very informative posts. I learn something new every time. I was thinking about getting either the PC3 or 5 this winter. This settled it for me.
#5 ·
Even tho a PC V is not an option for my bike I spent a TON of time reading about calling companies about and reading some more about these auto tuning systems for my fiancees bike and this is pretty much spot on from what even dyno jett told me. Ive said this before on here but Ill say it again. A dyno jett associate told me over the phone that he would recommend a pc3 with a custom tune over a PC V any day even tho he knows his company makes more money on the later. He told me they honestly only produced a self tuning device to take sales from Bazzaz. He said Bazzaz and its owners were long time now bragging about things like controlling all 8 injectors and auto tune. He said these features are USELESS on the street only bikes and it was dynojetts wishes to continue to offer the PC at a lower more reasonable price with out features we didnt need. The time came how ever where they had to show they could do the same things as their competition and STILL did it cheaper.
