fuse location
1.1K views 4 replies 3 participants last post by  gsxrandy
#1 ·
Just tryed to see what code would come up in dealer mode and I think I blew a fuse.I crossed the jumper wire and herd a pop.I took the wire of the white thing that you was suppose to put the jumper wire in.Went to turn the bike on everything cameon and works lights,horn,blinkers,etc it just won't start when I pull the clutch in and hit the start button.If it is the main fuse Which is 30AMPS where is it located and how do I get to it.I see the fuse box with the 10A AND 15A.I have a GSXR750 07.l like I said everything do comes on and works just won't start.I would really need some help on this and if someone have a pic where it is located.
Thanks!
#5 ·
ya usualy if you cant hear a clicking then its the solinoid that is not geting power which is a low amp circute the starter motor is a high amp and if it clicks and doesnt turn over then it has to do with the motor or the 30 amp fuse. the solinoid is used so a low amp switch can be used to triger the starter motor. its basicly a magnet
