Alrighty. before I go into detail here, im working with a 2007 gsxr600. has about 16000 miles. My problem here has started off last year by a lopey idle, well actually it was like that when I bought the bike, and I went out on a lim too because what I read on line was that that these bikes (sometimes just have lopey idles) well, my idle is a little more cammed out sounding. so anyhow, recently when my bike is cold, only sometimes, more frequently now than it was before, but still sometimes when I start it, it will idle at like 1200rpm, then the idle drops as it should, (obviously to like 900-800 rpms, when it normally drops to like 1400rpm) but with my lopey idle problem it kills the bike. so I start it again and it will only start if I feed it the throttle, once I have the bike running, it runs rich and the odor of gas lingers and the nice white smoke comes about.. I can void this problem by either waiting until the bike is warm, then my lopey idle problem goes away, and the bike runs perfect. OR I can wait until it reaches about 100 degrees then shut the bike off and start it back up and if I get lucky, it will start back up and run perfect. so I was thinking here, well maybe its a sensor? O2 sensor maybe? but I questioned myself why it isn't throwing a code for the sensor or any codes at all? has anyone ever had problems with any sensors where they did NOT throw an emissions code to let them know it is faulty? it would be more of like a hit or miss thing with changing all of these parts around that cant be tested; now some are gonna say, did you change your plugs? Yes. clean gas? yes. air filter? yes. Some will say its my valves, but I doubt it because, if it WERE to be my valves, it would be more of a constant thing rather than when its just cold. I did all of the "first check" things. but maybe by some chance I over looked something,... but I doubt it. could this be a symptom of a faulty stator? or what sensors could be doing wrong here? This is just my first fuel injected vehicle. im used to carburation, not that this really makes a difference about knowing things or not, because an engine still needs the same things to function properly.. I just would like to train my brain and learn more of why my bike is being a piece of sh*t :lick::Laughing: Thanks guys.. big help!!!
