Hey i was wondering how or if there is any advice on changing hand grips as well as the clutch and brake lever? i get them in the mail today so i dont wanna screw anything up being im a newb at this lol
Funny enough, another member on here had the same problem only days ago. The rubber stopper which the screw screws into has been pushed too far into the bar. You need to remove the bar ends and try to draw the rubber bit back out. Either get a longer screw and gently screw it a little way into the rubber stopper and then pull it back out or find something long and thin (no jokes please!!) which you can hook into it so you can draw it back out. Once out enough, the knack is to very gently screw the bar end screw into the rubber stopper; too fast or too firm and you just push it back in. The screw needs to grip it before you can really screw it in.ok so the levers were easy enough (the brake is a lil lose if u shake it up and down)..... the grips ended up not fitting on but after i slid the old ones back on i went to screw the screw in and it didnt really stay.... i think it was just screwing into the little rubber thing so bascially i could just push the screw in and out.... anyone have any idea how to fix this? thankks
